Soldered Relay Arduino Library installation not working
I am unable to install the Soldered Relay Arduino Library from GitHub - SolderedElectronics/Soldered-Relay-Arduino-Library · GitHub. I have unzipped the file and placed it in my Arduino Library folder, but can’t find the library to install.
Originally submitted via email support on 15 October 2025. Migrated to the forum for community visibility.
Check the path and how the file was extracted. If the unzipped folder contains another folder inside it, and the library is nested further down, it won’t work. The library needs to be directly in the /libraries folder.
You don’t need to install anything else through the library manager - manual placement in the /libraries folder is sufficient. The library manager search doesn’t work reliably with this library.
Instead, copy-paste any of the example .ino files into a new Arduino project. Simply include “Relays-SOLDERED.h” in your sketch and use the library as normal - it should compile and work OK.
