SSD1306 OLED Display pinout: VCC GND SCL SDA vs SCL SDA VCC GND
I need to clarify some technical issues. Can we discuss this directly?
Originally submitted via the contact form on soldered.com on 9 September 2025. Migrated to the forum for community visibility.
We provide technical support by email. Please write your question and I’ll provide the details you need.
For this product, you can check out the hardware files:
Schematics are in the OUTPUT folder. You can also check out the other documentation:
Can you confirm whether you offer the module with a pre-assembled 4-pin header in the pinout arrangement VCC GND SCL SDA with a 3.3V supply? Since the module is based on the SSD1306, I assume this option is available.
Attachment omitted in migration: image003.jpg
The pinout arrangement differs. Ours is SCL, SDA, VCC, GND (from the front). It won’t work as a drop-in replacement for a module with a different pinout like VCC GND SCL SDA.
