is it possible to build an ssh terminal based on inkplate 6motion?
- connect to ssh server over wifi
- connect keyboard via usb-c
- store ssh keys
Hi @hi1
It is possible, but we don’t have ready-made SSH terminal firmware for the Inkplate 6MOTION, so you would need to do some tinkering yourself..
The board uses an ESP32-C3 for WiFi, so the SSH connection can go through it. You can store the SSH keys in the ESP32-C3 flash, the STM32 flash or on the microSD card.
The keyboard is a problem because the USB-C port goes to a CH340 USB-UART chip and is used for programming, power and charging. It is not wired to the STM32 USB peripheral, so you can’t plug a keyboard into it.
The simplest solution is our Inputronic BRIDGE ( Inputronic BRIDGE - USB HID to I2C/UART/SPI for Arduino – Soldered Electronics ). It has a USB-A port for a keyboard and sends the key data over I2C, UART or SPI, so you don’t need a USB host stack.
Alternatively:
- You could connect a BLE keyboard to the ESP32-C3 but we don’t provide firmware or support for that.
- The STM32 has USB OTG signals available on the K28 header (you can check the schematic for it), so you could connect a USB connector to them with your own breakout. You would also need to provide 5 V for the keyboard and write the USB host firmware.
thank you for such detailed response!
The USB-C limitation is the part worth pinning down first, since a keyboard was central to your idea. If the CH340 path is only wired to the ESP32-C3, then the USB OTG pins on the K28 header sound like the cleaner route if you’re willing to add your own connector and 5 V supply. That still leaves writing a USB host stack, which is a real chunk of work. The Inputronic BRIDGE over I2C looks like the lower-risk start, though it adds a second board to your build.
