The Whole Datasheet of 109113
We research a model 109113 from mouser and would like to use it in our product, but I can't find the Light intensity and pin information, could you please send me the whole datasheet.
Hi @yichuan_guo
You can find the datasheet attached below
Soldered_109113 5mm rgb led diode common anode+.pdf (209.8 KB)
Hello,
I have seen this datasheet, but there is no light intensity(mcd) and the which pin is Red, which Pin is GREEN…
Hello,
It follows the standard RGB diode pinout, available in this image:
We unfortunately do not have the light intensity specification available.
Thank you. How can i evaluate the brightness?
Do you have the lead pitch parameter? Like this:
We do not have said measurements at the moment, we have requested them now from our Chinese supplier. In the meantime i have found a datasheet for a similar RGB diode whoce dimensions are the same to ours (i have compared our led to the tolerances of the linked datasheet) so you can take these as a loose reference until the datasheet for this specific LED arrives: https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/8939/4491_LEDDC-5CARGB.pdf
