I’m wondering if the LED indicator on the switches is always active, or only when the contacts are closed?
Naziv firme: Rinka d.o.o Adresa: [address removed]- Bajnice Mjesto:[address removed]: Zanima me jeli svjetlosna indikacija na prekidačima uvijek aktivna ili samo kada su kontakti zatvoreni ?
Originally submitted via email support on 22 February 2022. Migrated to the forum for community visibility.
The LED diode on the button is completely separate from the button contacts, so you can connect it however you like.
hvala Vam na upitu.
Vezano za svjetlosnu indikaciju, LED dioda na tipkalu je u potpunosti odvojena od kontakata tipkala tako da ju možete spajati po želji.
Ukoliko imate još pitanja, slobodno se obratite.
How do I connect it so the indicator lights when the switch contacts are closed, if I’m switching +24V but the indicator runs on 5V?
Zanima me još samo kako da spojim da indikator svijetli kad su kontakti prekidača spojeni ako prekidam + 24v , a indikacija radi na 5 v
Depending on what you’re powering and how your device works, you might be able to draw 5V from it and connect that to the LED - it will then light when you turn on the device via the switch. If there’s no 5V available on the device, you should add a series resistor with the LED diode.
Ovisno što napajate i kako uređaj radi možda možete s njega dovesti 5V na diodu te će onda i onda raditi kada upalite uređaj pomoću prekidača. Ako na uređaju nema 5V onda bi ste trebali dodati serijski otpornik s LED diodom.
