TowerPro SG90 torque for solar tracker application
I’m looking at the Servo Motor TowerPro SG90 for a solar tracker application with 2 PV panels (5W solar panel with aluminum frame). What is the torque (kg/cm at 5VDC)?
za SERVO MOTOR TOWERPRO SG90
koji moment ( kg/cm kod 5VDC) ima?
Kanim ih koristiti za solar tracker za 2 PV ploče
5W SOLAR PANEL, ALUMINUM FRAME
( Made in e-Radionica)
Originally submitted via email support on 18 January 2017. Migrated to the forum for community visibility.
According to the datasheet, the SG90 has a torque of 1.8 kg/cm. This model may be underpowered for your solar tracker application.
mislim da je preslab ovaj model. Prema datasheetu 1.8 kg/cm : https://e-radionica.com/hr/blog/2016/06/23/kkm-servo-motor-tower-pro-sg90/ Svakako Vam obavjestimo ovdje.
Check the Servo & Stepper Motors category for newer servo options that may be better suited: Ostali senzori | Svestrani senzori za elektroniku – Soldered Electronics - these have torque up to 18 kg/cm.
pogledajte sada našu kategoriju “Servo & Stepper motori”, imamo dva nova Servo-a, pa možda će nešto odgovarati: Ostali senzori | Svestrani senzori za elektroniku – Soldered Electronics
Moment im je do 18kg/cm.
