Using ED060SC7 display with ESP32 without Inkplate board
I found an old e-reader with an ED060SC7 display. Is it possible to buy an Inkplate board without the display? Or is there another way to connect this display to an ESP32?
Originally submitted via email support on 2 March 2022. Migrated to the forum for community visibility.
Inkplate is only sold as a complete product with both the PCB and e-paper display. E-paper is complex to drive because it requires a power supply with different voltages, which needs a dedicated IC. Additionally, the ESP32 does not have enough pins to directly drive e-paper—you must use an IO expander. This makes it difficult to connect an e-paper display without the integrated Inkplate solution, as e-paper requires additional supporting components to function properly.
