Can I use two slider potentiometers in Arduino and if so, how do I reference the second slider?
Originally submitted via email support on 3 February 2024. Migrated to the forum for community visibility.
Yes, you can use two sliders. The address selector switch allows you to change the address of the second slider. Refer to the guide for which I2C addresses map to which switch position.
Alternatively, when you connect everything, simply use an I2C scanner sketch to find out the address of the second slider: Soldered-Hacky-Codes/I2C_Scanner/I2C_Scan/I2C_Scan.ino at main · SolderedElectronics/Soldered-Hacky-Codes · GitHub
