VK172 GPS module official driver link not working
I received the GPS module and tried to connect using the official link provided on your website, but got a message that the page doesn’t work. Can you help?
stigao mi je GPS modul i pokušao sam se povezati na službene stranice preko linka koji je na vašim stranicama i dobio sam poruku da stranica ne radi pa molim pomoć.
L.p. [name removed]
Nema virusa.www.avast.com
Originally submitted via email support on 7 August 2023. Migrated to the forum for community visibility.
The manufacturer appears to have removed that official link for some reason. A user posted driver files on their forum here: u-blox Portal
Since it’s an .exe file, I verified it for safety - the file for V2.30 is clean and I recommend that driver.
I also found the documentation for the driver: https://content.u-blox.com/sites/default/files/products/documents/u-blox-GNSS-Sensor-and-VCP-Device-Driver_UserGuide_% %29.pdf
pregledao sam stranicu tog proizvođača i izgleda da su makli taj službeni link iz nekog razloga.
Ovaj korisnik je na njihovom forumu postavio file-ove za te drivere: u-blox Portal
Zbog toga što je samo .exe file, išao sam provjeriti je li riječ o virusu za svaki slučaj - i datoteka za V2.30 je OK, preporučujem taj driver.
Pronašao sam i dokumentaciju za taj driver: https://content.u-blox.com/sites/default/files/products/documents/u-blox-GNSS-Sensor-and-VCP-Device-Driver_UserGuide_% %29.pdf
Javi ako radi OK i hvala što si javio kako bi mogli imati točno ažuriran sadržaj na našoj web stranici.
