VL2330 coin battery charging circuit design
I found the charging and discharging technical specifications for the VL2330 battery:
https://industrial.panasonic.com/cdbs/www-data/pdf/AAA4000/AAA4000COL17.pdf
https://industrial.panasonic.com/cdbs/www-data/pdf2/AAA4000/AAA4000C398.pdf
https://industrial.panasonic.com/ww/products/batteries/primary-batteries/lithium-batteries/coin-type-rechargeable-lithium-batteries-vl-series/VL2330
evo upravo sam pronašao i tehničke karakteristike punjenja i
pražnjenja baterije VL2330 :
Lijepi
Pula
25.10.2018. u 15:31, Tech support:
Originally submitted via email support on 25 October 2018. Migrated to the forum for community visibility.
Based on your information, the current consumption is very small (50mA over 18 months), and you can solve this problem in several ways:
a) Always have a source that will charge the internal battery, with cables drawn from the battery as you suggested
b) Same as (a), but powered from another, larger battery
You have a source (battery or wall adapter) which goes through a charger to the battery. According to the datasheets you provided, the charger should charge with very small current. In this document: https://industrial.panasonic.com/cdbs/www-data/pdf/AAA4000/AAA4000COL17.pdf on page 2, first figure, the row for VL2330 shows that the battery should be charged at 3.5V with a 180ohm resistor in series. The diode protects against current backflow and a regular voltage regulator can be used here.
You need:
a) a power source
b) a voltage regulator set to 3.8V
c) a Schottky diode
d) a 180ohm resistor
If your source is an AC adapter, you can easily lower the voltage to 3.8V with a regulator: Step-down modul s LM2596S – Soldered Electronics
You can always use a Schottky diode: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
And a 180ohm resistor of any power rating.
If your source is another battery, it’s best to use an LM317 and tune its output to 3.8V: https://e-radionica.com/hr/lm317-podesivi-regulator-napona.html
hvala Vam na upitu i isprike na našem kasnom odgovoru.
Nažalost, ne možemo ovaj projekt odraditi za Vas, ali možemo ovako u slobodnom stilu prokomentirati par ideja kako riješiti ovaj problem.
Prema Vašim info, čini se da je potrošnja iznimno mala (50mA u 18 mjeseci), ovaj problem možete riješiti na više načina:
a) imati uvijek izvor koji će puniti internu bateriju, s izvučenim kablićima iz baterije, kako ste i predložili
b) isto kao i a, ali se napaja iz druge, veće baterije
Dakle, imate izvor(baterija ili zidni) koji kroz punjač ide do baterije. Punjač, prema datasheetovima koje ste poslali, treba puniti vrlo malom strujom. U ovom dokumentu: https://industrial.panasonic.com/cdbs/www-data/pdf/AAA4000/AAA4000COL17.pdf
na stranici 2, prva slika
redak za VL2330
prikazano je da bateriju treba puniti na 3.5V s otpornikom u seriji od 180ohm, dioda je za zaštitu toka struje te je tu najobičniji regulator.
Dakle, trebate:
a) izvor
b) regulator na 3.8V
c) schottky diodu
d) 180ohm otpornik
Ako je izvor strujni(iz utičnice, npr.: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics), s ovim regulatorom možete vrlo lako spustiti napon na 3.8V: Step-down modul s LM2596S – Soldered Electronics
Schottky dioda uvijek možete koristiti Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
i 180ohm otpornik bilokoje snage
Ako je izvor druga baterija, najbolje je uzeti LM317 i njegov izlaz naštimati na 3.8V https://e-radionica.com/hr/lm317-podesivi-regulator-napona.html
Za sva ostala pitanja stojimo na raspolaganju.
