Water Detection Module connection to micro:bit
How do I connect the Water Detection Module to a micro:bit?
Pozz,mozete li opisati koko se spaja s microbitom vas proizvod "Modul-Detektor postojanja vode?
Originally submitted via email support on 21 January 2018. Migrated to the forum for community visibility.
Connection is straightforward: connect power and communication, then read the pin on the micro:bit as HIGH or LOW (water present or absent). Use the potentiometer on the board to adjust the output sensitivity.
micro:bit sensor
3V +5V
gnd gnd
0(ili 1 ili 2) DO
spajanje bi trebalo biti jednostavno; spojite napajanje te komunikaciju, a na micro:bitu očitavajte taj pin kao HIGH ili LOW(ima/nema struje). Pomoću potenciometra na pločici podesite osjetljivost tog izlaza.
micro:bit senzor
3V +5V
gnd gnd
0(ili 1 ili 2) DO
