Water flow meter G3/4 FS300A real-time flow monitoring
How are results read from the Water flow meter G3/4 (101643), and can flow be monitored in real time?
Zanima me u vezi Vašeg proizvoda “Mjerač protoka vode G3/4” (101643) na koji način se očitavaju rezultati, te može li se u realnom vremenu pratiti protok?
Originally submitted via email support on 12 February 2018. Migrated to the forum for community visibility.
The water flow sensor (FS300A) continuously provides flow information on the communication wire. It is a hall effect sensor which outputs a signal for each complete rotation of the internal turbine. A microcontroller registers this signal and converts it to a value in L/min or similar.
hvala Vam na upitu.
Naš senzor protoka vode(FS300A) konstatno daje informaciju o protoku na žici za komunikaciju. Radi se o hall effect senzoru koji svaki puni okret unutarnje turbine daje signal kojega registrira mikrokontroler te pretvara u vrijednost L/min ili sličnu.
