Water Flow Sensor 0-60 L/min output signal and range options
I’m interested in learning about the output signal of this water flow sensor. Do you have a water flow sensor that measures in the range of 0-10 L/min?
javljam Vam se u vezi ovog mjerača protoka (
Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics), zanima me koji mu je izlazni signal i imate li možda mjerač protoka vode koji mjeri u rasponu od 0-10l/min?
Originally submitted via email support on 10 April 2018. Migrated to the forum for community visibility.
You can see the details here: https://www.openhacks.com/uploadsproductos/g3_4_water_flow_sensor_-_wiki.pdf
It uses a Hall effect output. By counting the signals within a second, you can calculate the water flow rate. The PDF also includes example code.
Unfortunately, this is the only water flow sensor we have.
možete pogledati ovdje detalje: https://www.openhacks.com/uploadsproductos/g3_4_water_flow_sensor_-_wiki.pdf
Radi se o hall effect izlazu, brojeći signale unutar sekunde možete izračunati protok vode. PDF ima i primjer koda.
Nažalost, ovo je jedini senzor protoka vode kojega imamo
