Water level sensor for septic tank overflow detection
I need a water level indicator for a septic tank—something that gives a signal before the tank overflows. Do you have anything like this?
Treba mi pokazivac nivoa u septickoj.tj.nekakav signal prije nego se jama prelije.Imate li tako nesto.Lp.
Originally submitted via email support on 2 June 2020. Migrated to the forum for community visibility.
We have a stainless steel water level sensor available, but we’re not certain it would work in such a system since it’s designed for use with water.
https://e-radionica.com/hr/senzor-razine-vode-od-nehrdajuceg-celika.html
hvala Vam na upitu. https://e-radionica.com/hr/senzor-razine-vode-od-nehrdajuceg-celika.html
