I’m looking for technical documentation for the water level sensor - how to connect it and how it works. I searched the website but couldn’t find it.
Pitanje vezano za senzor razine vode, jel postoji gdje kakav tehnički list ili nešto kako se spaja i kako funkcionira, tražio sam na stranici no nisam mogao naći
Originally submitted via Facebook on 6 July 2019. Migrated to the forum for community visibility.
Is this the sensor you’re asking about? Senzor razine vode - precizno otkrivanje tekućine – Soldered Electronics
Pozdrav [name removed], hvala na upitu. Radi se o ovom senzoru? Senzor razine vode - precizno otkrivanje tekućine – Soldered Electronics
Check out the tutorial here: https://e-radionica.com/hr/blog/2019/07/08/float-sensor/
[name removed], pogledaj tutorijal ovdje: https://e-radionica.com/hr/blog/2019/07/08/float-sensor/
