I need information about the electronic water valve. If my water meter is located about 100 m away from the house, there could be a pipe rupture underground that I would only notice from a high bill since I don’t know what’s happening below ground until the pipe enters the house. Can the valve installed near the meter detect a pipe rupture? What is required for it to work?
trebao bih informaciju o ovom proizvodu https://soldered.com/hr/proizvod/elektronski-ventil-za-vodu-12vdc/
Ako se brojilo za vodu nalazi udaljeno od kuće oko 100 m moguće je puknuće cijevi za koje bi znao tek po velikom računu jer ne znam što se događa ispod zemlje do ulaska cijevi u kuću.
Može li gore navedeni proizvod koji bi bio smješten uz brojilo prepoznati puknuće cijevi? Što je potrebno za njegov rad?
Originally submitted via email support on 12 June 2024. Migrated to the forum for community visibility.
