What battery for Inkplate 5Gen2?
Hi, I made a mistake and ordered an Inkplate 5Gen2 WITHOUT enclosure and battery - so now I have to order those items separately.
The casing seems to be this item: Enclosure for Inkplate 5Gen2, black - Soldered Electronics
But what battery goes with the 5Gen2 - and fits inside the enclosure?
Thank you,
Philippe
Hi @philippesimpson
Battery included with Inkplate 5 is this one. You could also use smaller ones or if you wish to use bigger ones you will need to change the 3D model to fit.
Thanks!
Li-Ion Battery 1200mAh 3.7V is currently sold out. Do you happen to know when it is back in stock?
One more question: Can you charge the battery directly via the Inkplate 5Gen2 board? Or do I need a special, separate charger?
Our supply chain says it will be back in about 2 weeks.
You can change the battery via the Inkplate board.
