WS2812 RGB LED Strip connection to Micro:Bit voltage compatibility
Can the WS2812 RGB LED Strip (PAMETNA RGB LED TRAKA WS2812 30LED/M 5V IP20) be connected directly to a Micro:Bit? We are interested in purchasing 10 units of these strips for educational use.
TRAKA ZA ODLEMLJIVANJE, 1.9MM - 3 kom Kockica Od LEDa - Set Za Učenje Lemljenja - 5 kom Stop Me Game - Set Za Učenje Lemljenja - 5 kom Simon Says - Set Za Učenje Lemljenja - 5 kom vidio sam da imate LED trake dužine 1m , dali se ove trake mogu spajati na MicroBit: PAMETNA RGB LED TRAKA WS2812 30LED/M 5V IP20 Lp, [name removed] Centar za kulturu [name removed] 9 01/6272 - 962
Originally submitted via email support on 29 October 2019. Migrated to the forum for community visibility.
The WS2812 RGB LED Strip operates at 5V, while the Micro:Bit board can output a maximum of 3.3V. Direct connection is not possible because the voltage is too low to ensure proper operation of the LED strip.
hvala Vam na upitu. Sama pametna RGB LED traka radi na 5V, dok Micro:Bit pločica može dati maksimalno 3.3V. Direktno spajanje u tom slučaju nije moguće jer se zbog premalog napona ne bi mogao osigurat pravilan rad LED trake. Molili bismo Vas da općenito za sva tehnička pitanja koristite naš forum: http://forum.e-radionica.com/hr/index.php
Attachment omitted in migration: Ponuda Centar_za_kulturu_Jastrebarsko_332_2019.pdf
