I recently got an RGB strip from you, but I’m confused about something (since you don’t have a tutorial on the site anymore). At the end of the strip I have 5 cut wires. It’s clear that green is ground, but I’m wondering which connection is between the other two red and white wires?
Poštovanje,nedavno sam kod vas uzeo RGB traku,no muči me jedna sitnica(obzirom da više nemate tutorial na stranici) na kraju trake sam dobio odrezanih 5 žica,jasno je da je zelena ground,no zanima me koja je veza između preostale dvije crvene ,odnosno bijele žice?
Hvala na odgovoru unaprijed
Originally submitted via email support on 11 August 2017. Migrated to the forum for community visibility.
Which LED strip are you referring to?
o kojoj LED traci se radi?
Red is power (+5V), and white wire is for control/communication. I’d also recommend using the Adafruit Neopixel library for controlling this LED strip!
crvena je napajanje(+5V), dok je bijela žica za kontrolu/komunikaciju.
Koristim priliku da odmah preporučim Adafruitov Neopixel library za kontrolu ove LED trake!
Thanks, but we measured with a multimeter and found that the white wires carry ground, the red ones carry 5V, and the green one is presumably for control? Do you have a tutorial you could recommend?
Hvala,iako smo preko multimetra dokučili da kroz bijele žice je ground,kroz crvene 5V a zelena je onda,pretpostavljam,za upravljanje?Imate li možda neki tutorial za preporučiti?
