10000 mAh Battery connector type and 3D model
The datasheet (https://soldered.com/productdata/2020/07/Soldered_10000-mAh_datasheet.pdf) shows the battery with tabs, but the product pictures show it with a cable and connector. Which is correct? If it has a cable, what type of connector is it?
Originally submitted via email support on 28 November 2025. Migrated to the forum for community visibility.
Is a 3D model available for this battery?
The battery has a JST-PH-2mm connector, which is compatible with Soldered boards as shown in the product pictures. A 3D model is not available, but you can approximate one from the dimensions provided in the datasheet.
