12mm red illuminated switch voltage and current specifications
What voltage and current is this switch rated for?
Zanima me za koji napon i struju je ovaj prekidač
Svjetlost, Boja i Slika | Vizualno Senzoriranje – Soldered Electronics
Hvala
Originally submitted via email support on 10 January 2020. Migrated to the forum for community visibility.
The back of the switch is marked 2A, 250VAC. The LED operates at 5V.
hvala Vam na upitu.
Na poleđini prekidača navedeno je 2A, 250VAC, dok sama LED dioda radi na 5V.
Ukoliko imate još pitanja, slobodno se obratite.
I need a switch for DC 24V with 3-4A capacity. Would this one work, or do you have other options?
Hvala Lp [name removed]
If the physical size is not important to you, you can try an SPST switch as an alternative.
isprike na čekanju odgovora.
Ukoliko Vam dimenzija prekidača nije bitna, možete probati sa: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
