I purchased an ATmega328P LoRa Board a few months ago and tried to use it for the first time today. I cannot upload code to the board. I’ve tried with an FTDI programmer and with another Arduino (Arduino UNO) in both ISP mode and regular serial mode. When I attempt to upload, I get the errors:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_recv(): programmer is not responding
Dobar dan,
kupoi sam kod Vas prije jedno 2-3 mjeseca, LoRA pločicu sa ugrađenim Atmega328P (https://soldered.com/hr/proizvod/atmega328p-mikrokontrolerska-plocica-s-lora-primopredajnikom-i-ipx-konektorom/). Danas sam tek imao priliku prvi put isprobati, ali nikako ne mogu prebaciti program na 328, probao sam sa FTDI programatorom i sa drugima Arduinom (Arduino UNO) i u ISP modu i u obicnom serijskom modu. Kada proboam prebacit kod dobijem greske:
"avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_recv(): programmer is not responding"
Hvala unaprijed!
Originally submitted via email support on 10 May 2023. Migrated to the forum for community visibility.
Can you send a screenshot of your ‘Tools’ menu in Arduino IDE so we can try to troubleshoot if the issue is with your configuration?
Also, have you tried:
- different USB cables
- different USB ports on your computer
- verifying that you selected the correct port in Arduino IDE
- verifying that you selected the correct board in the board manager
These are the most common upload errors, so it’s always good to double-check them all. Let us know the results and we’ll see what to do next.
isprike na kasnom odgovoru!
Možeš li poslati screenshot svog ‘Tools’ izbornika u Arduino IDE-u da pokušamo otkloniti problem ako je do konfiguracije?
Također, jesi li isprobao:
različite USB kablove različite USB portove na računalu jesi li siguran da si dobro izabrao port u Arduino IDE-u? jesi li siguran da si izabrao dobar board u board manageru?
Ovo su najčešće greške pri uploadu koda pa ih je uvijek dobro sve još jednom provjeriti.
Javi se s rezultatima pa ćemo onda vidjeti što dalje.
The board definition you need to have installed is called ATmega328p LORA, not Arduino UNO. This is the link for the board definitions you need to add to Arduino IDE:
https://raw.githubusercontent.com/SolderedElectronics/Croduino-Board-Definitions-for-Arduino-IDE/master/package_Croduino_Boards_index.json
Install the boards and select ATmega328p_LORA in the board manager. Upload should then work via USB first, then you can try the programmer. If using the programmer, try different options in the ‘Programmer’ section of the ‘Tools’ menu if it doesn’t work on the first attempt.
board definition koji bi trebao biti instaliran je naziva Atmega328p LORA, dok je kod tebe Arduino Uno. Ovo je link za board definition-e koje trebaš dodati u Arduino IDE-u
Instaliraj boardove i board koji treba postaviti je naziva ATmega328p_LORA
Upload bi onda trebao raditi, isprobaj prvo preko USB-a pa onda preko programatora. Sa programatorom isprobaj različite opcije u ‘Programmer’ sekciji ‘Tools’ izbornika ako ne radi od prve.
