ATmega328P LoRa board documentation and setup
Do you have any documentation for the ATmega328P microcontroller board with LoRa transceiver and IPX connector?
Imate li mozda neke dokumentacije za ATmega328P microcontroller board with LoRa transciever and IPX connector?
Originally submitted via email support on 3 May 2025. Migrated to the forum for community visibility.
Here’s the schematic for that board. It shows how the LoRa module is connected via SPI.
You can use the Arduino UNO board definition with this board. If that doesn’t work, try Arduino Nano.
This library should work with that LoRa module: GitHub - SolderedElectronics/Soldered-LORA-RFM96W-Arduino-Library · GitHub
Since this is a retired product, that’s all the data we currently have. If there’s something specific you’re interested in, let me know and I’ll try to look into it.
evo shema tog boarda u prilogu. Iz nje se vidi kako je LoRa modul spojen preko SPI.
Može se koristiti Arduino UNO board definition s ovim boardom. Ako ne, onda Arduino Nano.
Mislim kako bi ovaj library trebao raditi s tim LoRa modulom: GitHub - SolderedElectronics/Soldered-LORA-RFM96W-Arduino-Library · GitHub
Zbog toga što je umirovljen proizvod, na žalost to su svi podatci koje imamo trenutno. Ako ima nešto specifično što te zanima reci i probati ću istražiti.
Attachment omitted in migration: Atmega328P-Lora.pdf
