I recently bought 5 ATtiny85 SOP8 (SMD) chips from another supplier. When I try to burn the bootloader and upload code to them, it fails completely. However, the same process works without any issues on regular ATtiny85 DIP8 chips. Is it possible these SMD chips are defective, or do they require a different upload method?
lijep pozdrav nedavno sam kupio 5 komada Attiny85 SOP8(SMD) (ne kod vas) ali kad idem spržit bootloader i uploadat nešto na njega neželi i neće dok mi sa običnim Attiny85 DIP8 sve radi bez problema.Postoji li mogučnost da su neispravni ili ti smd čipovi trebaju neki drugi način uploada.kolko vidim ne.hvala na odgovoru
Originally submitted via Facebook on 9 March 2018. Migrated to the forum for community visibility.
