Battery-powered ESP32 project with RTC and SIM800L: optimal power management
I have a project powered by a 12V battery with a step-down converter to 4.1V. The project consists of an ESP32, RTC, SIM800L and several sensors. I’m looking for a solution to maximize battery life since the device is in a remote location. I’ve experimented with sleep modes and the TPL5110, but have a problem with sleep mode because the SIM800L must be powered directly from the buck converter, and with the TPL5110 I don’t have control over the exact timing of SMS transmission since the timer’s maximum duration is 2 hours.
The ideal solution for me would be a module like the TPL with very low power consumption, but triggered not by a timer, but by a signal from the RTC. So after the code executes, a done signal from the module, and then power-up again triggered by a signal to the module, but from the RTC’s set alarm time.
Since I’m not a technical person, maybe this is a simple and trivial question. From what I’ve researched, a relay doesn’t seem to be what I’m looking for. Or maybe it is?
Do you have any other recommendations?
Dobar dan, Imam projekt koji je napajan 12V baterijom sa step-down na 4.1 V. Projekt se sastoji od ESP32, RTCa, SIM800L i nekoliko senzora. Tražim rješenje za maksimiziranje trajanja baterije jer je uređaj na udaljenoj lokacji. Igrao sam se sa sleep-om i TPL5110, ali mi kod sleepa problem radi što SIM800L mora biti napajan direktno sa buck konvertera, a kod TPLa nemam kontrolu točnog vremena slanja SMSa jer je maksimalno trajanje trimera 2h. Idealno rješenje bi mi bio modul poput TPLa sa jako niskom potrošnjom, ali da se uključuje ne na trimer, već na signal sa RTCa. Dakle, nakon izvršenog kod, signal na done od modula, a uključivanje opet signalom na modula, ali sa postavljenog vremena alarma RTCa. Kako nisam tehničke struke :), možda je ovo pitanje jednostavno i banalno. Što sam istraživao, relej nije ono što tražim. Ili možda jest? Imate li možda kakvu drugu preporuku?
Originally submitted via email support on 11 March 2023. Migrated to the forum for community visibility.
A possible solution is to use two separate power supplies. One power supply for the SIM800L, and another power supply for everything else (ESP32, sensors, RTC, etc.).
With this configuration you can control the SIM800L power separately and independently control power to everything else connected to the other supply.
hvala ti na javljanju te se nadam da ću ti uspjeti pomoći.
Možda najbolje rješenje je da imaš 2 odvojena napajanja. Jedno napajanje za SIM800L, a drugo napajanje za sve ostale stvari (ESP32, senzori, RTC itd..).
Preko ove konfiguracije možeš posebno paliti/gasiti SIM800L i zasebno paliti/gasiti sve ostalo spojeno na drugo napajanje.
