I have a question about the BME280 atmospheric sensor. Is it compatible with Arduino Uno? Can I connect it to Arduino Uno or only to Croduino? In general, can I use your sensors with Arduino Uno?
Lijepi pozdrav!
Imam jedno pitanje u vezi atmosferskog senzora bme280. Zanima me dali je kompatibilan s Arduinom Uno. Mogu li ga spojiti s njim ili moram samo s Croduinom? I općenito, mogu li vaše senzore koristiti s Arduinom Uno?
Originally submitted via email support on 22 November 2019. Migrated to the forum for community visibility.
All our products are 100% compatible with Arduino boards, including the BME280. Croduino is the Croatian version of Arduino. It is programmed in the same way as Arduino (from the Arduino IDE) and can be used in various projects and systems just like Arduino.
hvala Vam na upitu.
Svi naši proizvodi su 100% kompatibilni s Arduino pločicama pa tako i BME280. Croduino je hrvatska verzija Arduina. Na isti način se programira kao i Arduino (iz Arduino IDE) te ga je moguće koristiti u raznim projektima/sustavima kao i Arduino.
Ukoliko imate još pitanja, slobodno se obratite.
