BME680 I2C communication with ESP32-C6 and library scaling issues
I connected a BME680 Environmental Breakout Board to an ESP32-C6-DevKitC-1 with VCC to 3.3V, GND to GND, SCL to Pin #6 (marked as 7 on the board) and SDA to Pin #5 (marked as 6). Using Arduino IDE with Soldered’s BME680 libraries, the begin() function fails and never connects to the device. Do I need to solder a jumper?
Originally submitted via email support on 10 April 2026. Migrated to the forum for community visibility.
Can you try a simple I2C scanner sketch to see if the device gets found over I2C? The BME680 should be totally compatible with the ESP32-C6 via the header pins.
I got it working by including Wire.begin(6,7) in the setup function. The default libraries were looking for the I2C pins at the wrong location on the board.
When reading one by one, the output shows: Temperature: 25.59 C, 78.06 F, Humidity: 432.66 %, Pressure: 102.55 hPa, Gas: 959.34 mOhm, Altitude: -101.33 m. When reading all at once: Temperature: 25.87 C, 78.57 F, Humidity: 43.47 %, Pressure: 1025.48 hPa, Gas: 988.78 mOhm, Altitude: -101.33 m (I2C addr: 118). The Humidity and Pressure values differ by a factor of 100 between the two read methods. Is this a scaling bug?
The scaling factor discrepancy is due to a library issue - the single read functions appear to parse the data incorrectly. This is not a sensor issue. I’ll forward this to the team to investigate and potentially fix the library. For now, I recommend using the read all function as many times as needed to get the correct data.
