CH340C (101918) package type and pinout information
I need to clarify the part number for the CH340C. The part number is 101918.
Originally submitted via email support on 25 July 2025. Migrated to the forum for community visibility.
The CH340C is a 16 pin package, the ‘C’ variant of the chip. According to the datasheet, it’s labeled as SOP-16. It’s possible that we have an error in our labeling of the specific packaging. Does SOP-16 fit your footprint needs?
I’m fine with it being SOP-16, but where did you get this information? When I click the datasheet link in the document at Access to this page has been denied. .pdf, I get another document, but it does not show the CH340C version. When you click the “datasheet” link in that document, it gives https://soldered.com/productdata/2020/02/Soldered_CH340_datasheet.pdf which again does not show the CH340C. If you could give me a link to a document with the correct information, I would appreciate it. I already made the board with a 20 pin footprint, but luckily only had 5 PCBs made.
I’ve checked the datasheet link and it seems to be incorrect as it doesn’t contain info on the CH340C version. You can find a datasheet which includes info for CH340C below. The package is SOP-16, not SSOP16. I’ve visually compared the two and it’s definitely the larger version (SOP-16).
Attachment omitted in migration: 35227cpdata.pdf
I have one final question. In your previous message you sent a screenshot of the chip with pin 8 as (OUT#/DTR#) but in the datasheet you sent me, pin 8 is (NC). Which is correct? I want to make sure I get the part correct to make another board.
I can check our schematic from one of our products, Inkplate 5gen2. Based on our PCB screenshot (Reference dot is in the bottom right corner), pin 8 is NC. The datasheet I originally found to screenshot for you had the chip labeled exactly the same as CH340C so I wasn’t aware the pinout would be different. I apologize for that, and I appreciate your attention to detail to avoid a potential error.
