Comparing 10-20V input with reference voltage using Dasduino Lite
I have a voltage input in the range of 10-20 VDC that I need to compare with a reference voltage and convert the comparison result to a binary output via an isolating contact, either a normally open or SPDT relay.
Štovani, imam naponski ulaz reda veličine 10 - 20 VDC pa bih isti usporedio sa referentnim naponom i vrijednost komparacije pretvorio u binarni izlaz, bespotencijalni kontakt, obični ili SPDT
imae li kakv prijedlog ?
[name removed] AUREL Zagreb
Originally submitted via email support on 11 January 2025. Migrated to the forum for community visibility.
There are two approaches:
If you already have a microcontroller that will measure the binary value, you can use the step-down module with LM2596S to reduce the input voltage to a lower level, then measure the output from that step-down converter using analogRead.
A more concrete solution is to use a Dasduino Lite and build a voltage divider with R1 = 10kOhm and R2 = 39 kOhm. This will linearly step down the voltage from 25V to 5V so it can be measured through analogRead on the Dasduino Lite and calibrated accordingly. Using the microcontroller this way also enables more operational options if you decide to do so in the future. In the code, you set an output pin to “1” whenever the desired condition is determined.
Evo dva prijedloga:
Ako već imate mikroupravljač koji će tu binarnu veličinu mjeriti, možete koristiti Step-Down Module With LM2596S – Soldered Electronics koji će spustiti ulazni napon na manju razinu, i onda s analogRead mjeriti izlaz sa tog step-down konvertera.
Malo konkretnije rješenje je uzeti Dasduino Lite i napraviti voltage divider gdje je R1 10kOhm a R2 39 kOhm, ovo će linearno spustiti napon od 25v na 5v tako da se može kroz Analogread na dasduino lite-u izmjeriti tražena vrijednost i kalibrirati tako. Također korištenje mikroupravljača na ovaj način omogućuje više opcija rada ako se ikad za to odlučite. U kodu se onda vrijednost nekog izlaznog pina stavlja na “1” kad god se odredi.
https://soldered.com/product/dasduino-lite/
Nadam se da su informacije korisne :slight_smile:
