CP2102 USB-UART Adapter receives data only on first command then fails
I have two issues with a CP2102 USB-UART Adapter. The adapter keeps resetting on its own. The receive data indicator LED remains inactive. I ordered a similar adapter about a year ago which works well, but two new ones are malfunctioning. I noticed the integrated circuits are different even though they use the same drivers. I use them with an SIM800L module - the older one works great, but the two new ones don’t.
Also, I’m having trouble logging into the forum with my account, though I can log into the store normally.
Javljam vam se povodom dva problema:
  1. Kontroler cp2012 ima problema sa radom. To se manifestira tako da se
kontroler sam resetira. Također vidim da dioda za primanje podataka
miruje. Najčudnija situacija je ta da sam isti naručio prije cirka
godinu dana i taj mi radi dobro, ali dva nova zezaju. Primijetio sam da
su zapravo integrirci različiti makar koriste iste drivere. Koristim ih
na SIM800L i stariji mi radi super, ali nova dva komada ne.
  1. Piše da se isti korisnički račun koristi za naručivanje i forum. Na
stranicu se mogu prijaviti normalno, ali na forum ne mogu.
Originally submitted via email support on 19 May 2021. Migrated to the forum for community visibility.
Since you’re unable to log into the forum, please provide information here about how you connected the CP2102 adapter, along with pictures.
s obzirom da se ne možete prijavit ina forum, molimo Vas ovdje info o načinu kako ste povezali CP2102 adapter, zajedno sa slikama.
The adapter I bought a year ago works fine - I’ve replaced the two new ones with it. I’m using the RX, TX, and GND pins from it. I’ve figured out that transmission from the adapter works correctly, but reception doesn’t work (I tested this with Arduino). I also ordered adapters with black cables (the ones currently on sale) which work fine on Linux, but I need this specific project to work on Windows. As a workaround for the serial adapter, I’m using a regular Arduino board with the ATMEL microcontroller removed.
I first noticed the problem in PuTTY when I started a session. Once I send AT to the SIM800L and get a response, but subsequent commands are not received (even if I send just AT again). With the same old adapter, the adapter with black cable, and the serial adapter from the Arduino board, everything works fine on the same SIM800L module.
Kao što sam napisao isti kontroler koji sam kupio prije godinu dana radi ok i njega sam ugradi umjesto dva nova koja sam naručio. Koristi sam RX i TX i GND pinove sa njega. I na kraju sam skužio da slanje sa kontrolera radi ok, ali primanje ne radi (testirao sam uz pomoć arduina). Inače sam bio naručio i one kontrolere u na Linuxu dobro, ali za ovaj dotični projekt mi treba da rade na windowsima. Kao zamjenu za serijski kontroler koristim običnu arduino pločicu sa uklonjenim ATMEL micro kontrolerom. Probleme sam prvo uočio u Putty-u kad bi pokrenuo sesiju. Jedanput pošaljem AT na Sim800L i dobijem odgovor ok, ali daljnje komande ne prima (makar opet napisao samo AT). Sa istim starim pločice radi sve ok na istom SIM800L modulu. [name removed] Software engineer Nomen d.o.o. Krešimirova 20 [address removed]
Thank you for the detailed explanation. Given how you’ve described the problem - it works initially but then fails - this is definitely an unusual issue. Can you connect the RX and TX lines on the CP2102 together and try to send something via Serial Monitor? The same data must “echo back” and be displayed in Serial Monitor. If this always works, then both the CP2102 adapter and IC are functioning, and the error is somewhere else.
hvala na detaljnim objašnjenjima. Isprike na pogreškama s kojima se suočavate.
S obzirom na to kako ste opisali problem, da na početku radi, a kasnije ne, definitivno je neobičan problem. Možete li spojiti RX i TX liniju na CP2102 zajedno i preko Serial monitora probati poslati nešto. To isto Vam se mora “vratiti”, ispisati u Serial monitoru. Ako to uvijek funkcionira, onda funkcionira i CP2102 adapter i IC, te je greška u nečemu drugome.
