CraftBot XL accuracy and tolerance specifications
I’m looking to purchase a 3D printer for production purposes in my company. I found the CraftBot XL on your website and reviewed the specifications regarding z resolution and accuracy in the x and y directions. Can the CraftBot XL actually achieve a tolerance of 0.004 mm in the x and y directions? Can you confirm the accuracy with a measurement certificate of a 3D printed CAD model of a cube 100 x 100 x 100 mm - specifically, if I create a CAD model of a cube 100 x 100 x 100 mm and print it without any changes to the CAD model, will the printer produce a cube measuring 100.004 x 100.004 x 100.002 mm?
kupujem 3D printer za potrebe proizvodnje u svojoj firmi.
na Vašoj internet stranici sam naišao na 3D printer
Bacio sam oko na specifikacije vezane za z rezoluciju i točnost u x y smjeru.
Da li Vaš 3D printer stvarno može postići toleranciju 0.004 mm u x y smjeru?
Da li Vi možete potvrditi točnost certifikatom izmjere 3D print CAD modela kockice 100 x 100 x 100 mm, tj, ako ja izradim CAD model kockice 100 x 100 x 100 mm, i bez ikakve promjene na CAD modelu, 3D printer meni izradi kockicu 100,004 x 100,004 x 100,002 mm?
Originally submitted via email support on 22 November 2018. Migrated to the forum for community visibility.
The tolerance in this case refers to the tolerance of stepper motor positioning, not the final print. The tolerance of the final print depends on many factors, including:
  • quality (chemical composition) of the plastic used for printing
  • moisture content in the plastic
  • print temperature
  • slicer settings
For this reason, manufacturers do not specify this data. From our experience, the tolerance on the final dimension is +2%.
hvala Vam na upitu!
Tolerancija u ovom slučaju označava toleranciju na pomak stepper motora, nažalost ne konačnog printa. Tolerancija konačnog printa ovisi o jako puno stvari, od kojih su možda najvažnije:
  • kvaliteta (kemijski sastav) plastike kojom printate
  • udio vlage u toj plastici
  • temperatura printa
  • postavkama slicera
Zbog toga ni proizvođači ne navode taj podatak. Iz našeg iskustva, tolerancija na krajnju dimenziju je +2%.
Ako imate još pitanja, budite slobodni javiti nam se.
