I want to build a circuit where Croduino performs some actions and then shuts itself off to save battery. The actions happen rarely, once a day or weekly, like watering. My idea is to turn it on with a button, and when it wakes up, a digital output goes HIGH and holds a MOSFET or relay that powers the board itself. When the output goes LOW, everything shuts down. I prefer using a MOSFET over a relay.
Version with button T1:
- The branch with button T2 does not exist
- I apply 5V to the gate, MOSFET conducts and I assume Croduino will turn on
- The button only needs to be held long enough for the digital output to go HIGH
What concerns me is the period when the digital output is directly connected to +5V via the button. Can this short the digital output? Should I add a resistor between the button and the digital output, like 10k?
Version with button T2:
- The branch with button T1 does not exist
- Same idea but I connect Croduino directly to the battery via the button and it should turn on and set the digital output HIGH
Here I’m concerned that there is a time when the Drain and Source pins of the MOSFET are shorted together and also connected to GND. Can this damage the MOSFET and the digital output?
One more question about the IRF540N. The datasheet says VGS (gate to source voltage) is ±20V and VGSth (gate threshold voltage) is 2 to 4V. Which should I actually follow? Can I apply 20V to the gate or is the max 4V? If the max is 4V, then I shouldn’t connect the digital output directly since it’s 5V. Maybe I should use a 330Ω resistor like for LEDs. In MOSFET switch examples for LED strips the gate is connected directly to the digital output. I’ve used Nova board with MOSFET before and there it was 3.3V so that wasn’t a problem.
[name removed] bok!
Prije svega, želim tebi i tvojoj obitelji sve najbolje za Božić i Novu Godinu i da vrijeme koje slijedi bude bolje i uspješnije od dosadašnjeg.
A sad pitanje. Imam sklop koji bi htio napraviti a nisam siguran jesam li ga dobro zamislio. Prvo ću riječima opisati namjeru a onda shemom pokazati.
Htio bi da Croduino izvede neke radnje i da se nakon toga sam ugasi, čisto radi štednje baterije. Radnja se odvija rijetko, jednom dnevno ili tjedno, npr. navodnjavanje. Ideja mi je da ga preko tipkala uključim, a kada se probudi, jedan dig. izlaz postavi u high i tako mosfet ili relej preko kojeg ide napajanje njega samog, drži uključenim. Kada izlaz ode u low, sve se gasi. Kod releja nemam dvojbi ali radije bi to riješio mosfetom. U nastavku slijedi shema na kojoj su prikazane dvije verzije, tipkalo T1 ili tipkalo T2.
Verzija s T1 tipkalom:
grana s T2 tipkalom kao da ne postoji na shemi
dovedem 5V na gate, mosfet provede i pretpostavljam da će se Croduino uključiti
tipkalo samo treba dovoljno dugo držati da dig. izlaz stigne otići u high
Ono što me muči je neki period vremena kada je dig. izlaz preko tipkala direktno spojen na +5V. Mogu li takvim spajanjem skuriti dig. izlaz? Možda otpornik između tipkala i dig. izlaza, npr. 10k?
Verzija s T2 tipkalom:
grana s T1 tipkalom kao da ne postoji na shemi
ista zamisao jedino što preko tipkala Croduino direktno spajam na bateriju i on bi se trebao uključiti i dig. izlaz pstaviti u high
Ovdje me muči što postoji vrijeme kada su DS pinovi mosfeta kratko spojeni i još k tome odvedeni na GND. Mogu li takvim spajanjem skuriti mosfet a onda preko njega i dig. izlaz?
I još jedno pitanje vezano uz IRF540N. U datasheetu piše da je VGS (gate to source voltage) ±20V, VGStg (gate treshold voltage) 2 do 4 V. Čega se zapravo treba držati? Smijem li na gate dovesti 20V ili je max ipak 4V? Ako je max 4V, onda ne bi smio direktno spojiti dig. izlaz jer je 5V. Možda da stavim otpornik 330R kao za diodu. U primjeru mosfeta kao prekidača za LED traku gate je spojen direktno na dig. izlaz. Ja sam spajao Novu i mosfet a tamo sam imao 3,3V pa to nije bio problem.
Attachment omitted in migration: WP_20171223_14_33_22_Pro.jpg
Originally submitted via email support on 23 December 2017. Migrated to the forum for community visibility.
