I’m a complete beginner with a question. After uploading a program to Croduino Basic 2, is it possible to disconnect it from the USB port and connect it to an external power source via a charger?
Totalni sam početnik i imam pitanje!
Da li je moguće nakon upload programa na Croduino Basic 2
odspojit sa usb porta i isti spojit na vanjski izvor napajanja preko punjača
hvala i ljep pozdrav!!!
Originally submitted via email support on 15 March 2016. Migrated to the forum for community visibility.
Yes, it’s possible. The code will remain stored on the Croduino. For external power via the USB connector, you can use 5V. If you have an adapter with higher voltage, connect it to the VIN and GND pins of the Croduino to avoid damaging the board.
moguće je. Kod će ostati spremljen na Croduinu. Eksterno napajanje možete, preko USB konektora, koristiti od 5V. Ako imate adapter s većim naponom trebalo bi ga spojiti na VIN i gnd pinove Croduina, kako se ne bi oštetila pločica.
Ako još imate nekih pitanja ili nedoumica, slobodno nam se obratite.
Ugodan dan.
