I received a new Croduino Basic 2 but I’m having issues again. First, my drivers went into hidden devices and I don’t know how to get them back working. Also, when I plug the board into my computer it shows: USB device not recognised, which never happened with my old replacement board. I need help.
Original message (Serbian)
stigao mi je novi croduino basic 2, ali opet imam problema.
Kao prvo driveri su mi otišli pod hidden devices i neznam kako da ih vratim u funkciju.
I još mi kada uštekam pločicu na računalo javlja mi: USB device not recognised što mi sa starom zamjenjenom pločicom nije nikad javljalo. Molim za pomoc.
Attachment omitted in migration: 1.jpg
Attachment omitted in migration: 2.jpg
Attachment omitted in migration: 3.png
Originally submitted via the contact form on soldered.com on 11 February 2017. Migrated to the forum for community visibility.
I don’t have experience with this type of case, but I’ve checked and we tested your board and it was fine. I found this article regarding hidden devices on Windows 10: Viewing Hidden Devices - Windows drivers | Microsoft Learn
It mentions several reasons why this might be happening. There is a program you can use to check if default drivers will work on your computer. Download links:
x64 OS: http://community.silabs.com/mgrfq63796/attachments/mgrfq63796/5%40tkb/29/1/UVCViewX64.zip
x86 OS: http://community.silabs.com/mgrfq63796/attachments/mgrfq63796/5%40tkb/29/2/UVCViewX86.zip
The program is called UVCView. With it you can see the VID (Vendor ID) and PID (Product ID). These are the values it should display:
VID: 0x10C4
PID: 0xEA60
Which computer are you trying to run the board on? Have you tried on another computer?
Podzrav [name removed],
moram priznati da nemam iskustva sa ovakvim slučajem. Upravo sam provjerio, Vašu pločicu smo testirali i bila je uredu. Nismo Vas posebno kontaktirali u vezi toga jer takve stvari se jednostavno događaju.
Pronašao sam ovaj “članak” u vezi skrivenih uređaja na Win10 sustavu : Viewing Hidden Devices - Windows drivers | Microsoft Learn
Spominje nekoliko razloga zbog kojih je moguće da se to događa.
Postoji program s kojim možete provjeriti hoće lči default driveri raditi na Vašem računalu. Link za preuzimanje je ispod:
x64 OS : http://community.silabs.com/mgrfq63796/attachments/mgrfq63796/5%40tkb/29/1/UVCViewX64.zip
x84 OS : http://community.silabs.com/mgrfq63796/attachments/mgrfq63796/5%40tkb/29/2/UVCViewX86.zip
Program se zove UVCView, pomoću njega možete vidjeti VID (Vendor ID) i PID (Product ID). Ovo su vrijednosti koje bi trebao pokazati:
VID : 0x10C4
PID : 0xEA60
Na kojem računalu pokušavate pokrenuti pločicu? Jeste li probali na nekom drugom računalu?
