Does the Croduino Basic 3 have a voltage regulator for 5V? I have a 6V power supply for my project.
možete li mi reći ima li navedena pločica regulator napona na 5 v jer mi je napajanje za projekt 6 V.
Lp [name removed]
Originally submitted via email support on 16 December 2023. Migrated to the forum for community visibility.
The board has a voltage regulator on it. The regulator input is connected to the VIN pin. You can connect your 6V power supply to the VIN input and the regulator will step down that voltage to the required 5V for the board to operate. If you power the board from USB, the voltage must be 5V.
Navedena pločica ima regulator napona na sebi. Ulaz regulatora je spojen na VIN pin. Možete spojiti 6V kojih imate za napajanje projekta na VIN ulaz te će regulator taj napon spustiti na potrebnih 5V za rad pločice. Ako pločicu napajate s USB-a onda napon mora biti 5V.
Where exactly is the VIN input located? I lost the schematic for the board.
Navedeni VIN ulaz gdje se točno nalazi, izgubio sam shemu pločice.
The VIN input is located on the header where the power pins are (3V3, 5V, GND, VIN, RST). This header is on the side where the analog pins are.
VIN ulaz se nalazi na headeru gdje su napajanja (3V3, 5V, GND, VIN, RST). Taj header je sa strane gdje su analogni pinovi.
Na slici se vide oznake pinova te gdje se nalazi VIN pin. Također šaljem i shemu pločice u PDF formatu.
Attachment omitted in migration: 2020-02-13T12_07_41.837Z-basic3_1.jpg
Attachment omitted in migration: Croduino Basic 3 Schematics.pdf
Attachment omitted in migration: Croduino Basic 3 PCB.pdf
