I have an old laptop with Windows XP that I want to use to output results, but I don’t know how to connect it to Croduino Basic. How do I install the required driver? I copied arduino.exe from a desktop computer where everything works fine.
Kada ce se moci kupiti Croduino (Basic ili 2)?
Nabavio sam jedan stari laptop sa Windows XP koji bi zelio
koristiti za ispis rezultata ali neznam ga spojiti sa Croduino basic. Kako se instalira potrebni driver?
arduino.exe sam prenio(kopirao) iz stolnog racunala na kojem sve dobro radi ,
- Sve najbolje povodom praznika i sretna Nova godina.
V. [name removed]
Originally submitted via email support on 25 December 2015. Migrated to the forum for community visibility.
The driver installation for Windows XP worked, but the connection is established on COM3 while Croduino looks for COM1. When running the program, I get the error:
“avrdude: set_open() can’t open device “\. com1”: The system cannot find the file specified.”
How can this be resolved? Can I change the COM port?
Hvala na uputama za instalaciju na Win XP.
To je uspjelo ali je veza uspostavljena na “com3” dok croduino traži “com1”
Prilikom izvođenja programa javlja se poruka:
Kako se to može riješiti ( promijeniti com port)?
I managed to change COM3 to COM1 and now everything works.
Uspio sam promijeniti com3 u com1 i sada je sve u redu.
Oprostite na preranom alarmu.
[name removed].
