I’m using a Croduino Basic in a project and almost every time I try to upload code I get the error: avrdude: ser_open(): can’t open device “\.\ COM5”: Access is denied. This doesn’t happen every time, but in 4 out of 5 cases.
Koristim Crouduino Basic u jednom projektu i skoro svaki put kad pokusavam uploadati kod mi se javlja error: avrdude: ser_open(): can’t open device “\.\COM5”: Access is denied. To se ne dogodi svaki put, ali u 4/5 slucajeva.
Originally submitted via email support on 15 April 2016. Migrated to the forum for community visibility.
Which board are you selecting in the Arduino IDE under Tools - Boards? If you’re using Arduino Nano or similar, please try the following (assuming Windows OS):
- Click Start, type devmgmt.msc or simply Device Manager, then press Enter
- In the middle panel, expand Ports (COM & LPT), right-click on one of the listed ports and select Properties (note which COM port it shows, such as COM4 or another)
- Select the Port Settings tab and click Advanced
- Click the COM Port Number dropdown menu and select one of the available ports
- Disconnect the Croduino. Connect it again and set the selected port in Arduino IDE under Tools - Ports
koji Board u Arduino IDE-u (pod Tools - Boards) koristite? Ukoliko Arduino Nano ili slični molim pokušati kako slijedi: (uz pretpostavku da koristite Windows OS) Klik na Start - upišite devmgmt.msc ili jednostavno Device manager, zatim Enter. Odaberite karticu Port Settings i klik na Advanced Klik na padajući izbornik COM Port Number, odaberite neki od slobodnih portova Isključite Croduino. Spojite ga ponovno, te postavite odabrani port u Arduino IDE pod Tools - Ports
I’m using Arduino Due or Diecimila in the Arduino IDE, and I tried the steps you mentioned but I’m still getting the same error. I tried with a different Arduino over the same USB port with the same code and it works fine.
U Arduino IDE koristim Arduino Due or Diecimila, a navedene korake sam pokusao i i dalje se javlja ista greska. Pokusao sam s kineskim Arduinom preko istog USB utora s istim kodom i sve je u redu
