Croduino Basic2 and NOVA ethernet shield with 8 relay modules
I’m planning to build an automation system for roller blinds. I need to control 8 circuits that I can open and close as needed, which I plan to do with 8 relay modules. I also need internet connectivity. Can Croduino run an ethernet shield and 8 relay modules at the same time?
Poštovani, imam jedno do dva pitanja vezana uz Croduino. Ukratok da Vam pojasnim o čemu se radi želim napraviti automatiku za rolete i trebam 8 strujnih krugova koje cu po potebi otvarati i zatvarati, to planiram rijesiti sa onih 8 releja. E sada moram biti i spojen na internet, pa dali Croduino moze raditi u isto vrijeme sa shieldom za ethernet i sa 8 relaja?
Hvala unaprijed
Originally submitted via email support on 1 June 2017. Migrated to the forum for community visibility.
Yes, Croduino Basic2 has enough pins for both at the same time. Also, consider Croduino NOVA if you’re interested in internet connectivity.
može, Croduino Basic2 ima dovoljno pinova za oboje u isto vrijeme.
Također, pogledajte Croduino NOVA ukoliko Vam je zanimljivo spajanje na internet.
