I’m a teacher at a technical high school and we have several Croduino Basic2 PB boards. I cannot connect to the board in Arduino IDE because I don’t have the drivers. The driver files listed on your website for Croduino2 and CP2102 don’t work. Could you please send me the correct drivers so I can use the boards.
Poštovani/ana, Isprike na smetnji. Nastavnik sam srednje elektrotehničke skole. Te posjedujemo vase croduino BASIC2 PB pločice. U arduino ide nemogu se spojiti sa pločicom zato što nemam drivere za croduino. Na vasoj stranici zip za drivere croduino2 i cp2102 ne rade. Pa bih vas molio da mi posaljete drivere da mogu koristiti unaprijed vam hvala.
Lp [name removed]
Originally submitted via email support on 19 January 2023. Migrated to the forum for community visibility.
Try this driver - it works correctly for me and I hope it will work for you as well.
Isprike na kasnijem odgovoru, nešto se dogodilo sa sustavom pa tek sad vidim.
Pokušajte ovaj, kod mene funkcionira kako treba pa se nadam da će i Vama.
Attachment omitted in migration: CP210x_Universal_Windows_Driver.zip
I’ve attached a driver with which I was able to get Arduino IDE to recognize the Croduino Basic 2. I’m not sure why it’s not showing up for you, but I’m sending it again.
Ispričavam se ako mi je nešto promaklo, nov sam ovdje pa se snalazim još.
Stavio sam u prilog driver sa kojim sam uspio da mi Arduino IDE prepozna Croduino Basic 2, ne znam zašto se ne vidi kod Vas.
Pošaljem Vam opet.
