Croduino Basic2 PB upload error in PlatformIO
I purchased a Croduino Basic2 and wanted to test it with a DHT11 sensor. I uploaded code to it using Atom with PlatformIO, but I’m getting an error message that I don’t know how to fix.
Kupila sam Croduino Basic2 i željela ga isprobati da vidim radi li, pri tom sam koristila dht11 senzor. Kod sam ubacila u Atom gdje imam PlatformIO, i kada uploadam pojavi mi se sljedeća greška koju ne znam kako popraviti.
Možete li mi Vi pomoći riješiti ovaj problem.
Attachment omitted in migration: 1E29021C424B4CA3AEE0844D266D3CF7.png
Originally submitted via email support on 30 May 2018. Migrated to the forum for community visibility.
Do you have a Croduino Basic2 with a “Croduino Basic2 PB” label on the back? From what I can see, the problem appears to be related to the signature, which is an issue with the PB version. Here are the instructions for Arduino IDE: https://e-radionica.com/hr/blog/2018/04/23/programiranje-croduino-basic2-pb-iz-arduino-ide/ Can you try using Arduino IDE instead of PlatformIO?
hvala na upitu!
Imate li Croduino Basic2 koji sa stražnje strane ima naljepnicu “Croduino Basic2 PB”? Koliko vidim iz slike(male je rezolucije), problem je u signature-u, a to je ta stvar s PB verzijom.
Ovo su upute za Arduino IDE: https://e-radionica.com/hr/blog/2018/04/23/programiranje-croduino-basic2-pb-iz-arduino-ide/
Možete li koristiti Arduino IDE umjesto PlatformIO?
I found this which you can try: Support for atmega328pb - #9 by Endre_Tk - FAQ - PlatformIO Community
pronašao sam ovo - pa možete probati: Support for atmega328pb - #9 by Endre_Tk - FAQ - PlatformIO Community
Inače, to nam je ograničena serija sa 100kom samo pa ste dobili baš iz te serije. Možemo Vam zamijeniti za klasični Croduino Basic2 koji će raditi direktno iz PlatformIO ako želite.
