We received a replacement Croduino 2 this week because we couldn’t connect to or upload any code to one of the 3 we ordered previously. Today when testing the replacement, the same thing happens. Normally when I connect the board it appears on COM4, but with the new one I get COM5, and during upload I get this info:
Sketch uses 926 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
What would you recommend we try to fix this without sending the board back, since the conditions don’t change when we swap boards - one works and the other doesn’t? Note that the LED on pin 13 blinks on the new board, probably because you tested the blink example to verify it, but I still can’t upload anything.
ovaj tjedan smo dobili zamjenski Croduino 2, jer jedan od 3
prije naručena nikako nismo mogli spojiti niti uploadati na njega
ikakav kod.
Danas pri testiranju zamjenskog mi se dešava ista stvar.
Inače kada spojim pločicu ona bude na COM4 portu, sada kad spojim
novoga dobijem COM5 port, i pri uploadu dobijem sljedeći info
30720 bytes.
Koja je preporuka da pokušamo to mi
rješiti bez slanja pločice nazad, jer uvjeti se ne promijene pri
minjenju pločica kada testiram a jedna radi druga ne.
ps. na novoj pločici led na pinu 13 blinka, vjerojatno jer ste vi
vjerojatno testirali blink example za provjeru, dok ja isi ne mogu
upladati.
Originally submitted via email support on 24 May 2018. Migrated to the forum for community visibility.
