Croduino Basic2 programming with Arduino IDE
Can I program the Croduino Basic2 using the standard Arduino IDE, or do I need to use different software? If I use Arduino IDE, should I set the Board setting to Arduino Uno?
S vaše stranice sam nabavio Croduino Basic2. Zanima me da li za njegovo programiranje mogu koristiti standardno Arduino IDE okruženje, ili moram koristiti neki sličan ali drugi softver. U slučaju da koristim isti, da li kod postavki za Board trebam postaviti na Arduino Uno.
Originally submitted via email support on 27 August 2017. Migrated to the forum for community visibility.
Croduino works fully with Arduino IDE. You need to install drivers. More details about Basic2 are available in the product documentation.
Croduino u potpunosti radi s Arduino IDE.
Ovdje možete vidjeti postavke: https://e-radionica.com/hr/blog/2015/08/19/arduino-ide-i-prvi-kod/
Trebate instalirati još drivere: https://e-radionica.com/hr/blog/2015/10/09/croduino2-i-cp2102-driveri/
Ako Vas zanima, ovdje se nalazi još detalja o Basic2: https://e-radionica.com/hr/blog/2015/10/11/novi-croduino-je-tu-croduino-basic2/
Sretno s projektom! Ako trebate još info - tu smo!
