Croduino Basic2 upload fails with AVRISP mkII programmer
I’m getting an error when trying to upload to my Croduino Basic2. Which programmer should I use? There are multiple options and AVRISP mkII is selected by default.
slika u prilogu. Koji je programator jer ih ima više a po defaultu mi je AVRISP mkII.
Attachment omitted in migration: Izrezak.JPG
Originally submitted via email support on 26 January 2018. Migrated to the forum for community visibility.
The driver and serial port look fine. The programmer choice doesn’t matter for regular upload - that option doesn’t affect standard uploads. All boards we ship are tested twice, so it’s unlikely this is a manufacturing issue. However, based on the information, something does seem wrong. Could you test on another computer if you have one available?
Driver i serijski port izgledaju u redu.
Programer nije bitan, tj. ta opcija ne utječe kada se radi običan upload
Sve pločice koje šaljemo testiraju se dva puta, tako da su prilično male šanse da se dogodi ovako nešto.. ali prema svim info, čini mi se da ipak nešto nije u redu. Mogu li Vas još zamoliti, ako imate neko druga računalo pri ruci, da probate na njemu?
