What is the maximum cable length for connecting a Croduino to sensors? Are there cables available in lengths of 50-100 cm?
Zanima me koja je najveca duljina kabla preko kojeg se mogu spojiti croduino i neki od senzora? Postoje li zice duljine od 50-100 cm?
Originally submitted via email support on 28 July 2016. Migrated to the forum for community visibility.
If you use your own wires/cables, 50-100 cm should not be a problem for any sensor. Finished cables with male/female connectors in those lengths may exist, but unfortunately we don’t have them in stock. You can improvise with other solutions.
ako koristite svoje žice/kablove, vjerujem da 50-100cm neće biti problem ni za koji senzor. U svakom slučaju, možete improvizirati
One more question/suggestion. Since I’m a beginner with electronic circuits, can you recommend what type of wire I should buy if I want to make my own cable, and where can I buy male and female connectors that can be soldered to the wire ends?
Još jedno pitanje/savjet. Budući da sam početnik u korištenju elektroničkih sklopova možete li mi preporučiti koju vrstu žice bi trebao kupiti ako sam želim napraviti kablić te mogu li se negdje kupiti muški i ženski konektori koji bi se zalemili za vrhove žice?
Since you’ll be using them to connect a Croduino and sensors, you don’t need any special cables. We recommend getting cables that match your sensors and Croduino (probably male-female) and extending them with stranded cable that you can get from any electronics parts shop.
s obzirom da biste ih koristili za povezivanje Croduina i senzora ne trebaju Vam neki posebni kablići. Preporučujemo da uzmete kabliće koji odgovaraju senzorima i Croduino (vjerovanto muško-ženske) te ih produljite nekim licnastim kabelom kojeg možete nabaviti u svakoj radnji s elektro materijalom.
