How do you connect Croduino Damba and/or Croduino Pico to Arduino/Croduino boards, and how are they programmed afterwards? I already have an Arduino Uno and one of these two would help me build a small weather station in my yard (temperature, pressure, humidity, gases).
Pozdrav! Zanima me na koji se način Croduino Damba i/ili Croduino Pico spajaju na Arduino/Croduino i kako se potom programiraju? Već imam Arduino Uno a jedan od ova dva navedena bi mi poslužio za izradu jedne male mjerne stanice u dvorištu (temperatura, tlak, vlaga, plinovi). Hvala!
Originally submitted via email support on 12 November 2015. Migrated to the forum for community visibility.
Damba has adapted pins so it simply plugs into Basic, while Pico requires connecting pins (5V, gnd, Tx, Rx and Reset). A tutorial for both will be available soon. We can send you the connection schematic later in the day. Keep in mind that Damba has only 6 I/O pins.
Pozdrv [name removed],
Damba ima prilogođene pinove tko da se samo “ubode” u Basic, dok se je za Pico potrebno povezati pinove (5V, gnd, Tx, Rx i Reset). Biti će ubrzo tutorial za oboje. Možemo Vam poslati shemu spajanja nešto kasnije poslijepodne? Imajte na umu da Damba rspolaže samosa 6 I/O pinova.
Can you send the schematic please.
Može shema molim Vas. Hvala!
Here is an image showing how to connect Damba and Pico so you can program them. If you want to program with a different USB to UART device, please let us know and we can adapt the instructions. Otherwise, the same process applies with possibly different pin layouts. You can find the pinouts here:
Damba - https://d3s5r33r268y59.cloudfront.net/33091/products/thumbs/2015-04-11T08:44:05.236Z-damba_pinout.jpg.855x570_q85_pad_rcrop.jpg
Basic (same for Pico) - Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
isprike na kašnjenju s odgovorom. U prilogu je slika koja pokazuje kako je potrebno spojiti Dambu, odnosno Pico kako biste ih mogli programirati.
Ukoliko želite programirati s nekim drugi USB to UART urađajem, molimo da javite pa ćemo prilagoditi. Inače, isti je postupak eventualno različit raspored pinova.
Pinout-e možete naći ovdje:
Basic(isto za Pico) - Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Attachment omitted in migration: prog.png
