I’m having trouble compiling and uploading a program to Croduino Damba. Code works fine with Basic2 (compiles and uploads), but when I try to move the program to Damba I can’t: 1. Compilation doesn’t work. 2. When I remove part of the code and compilation succeeds, the upload doesn’t work. I need some guidance.
Pozdrav, imam problem sa kompajliranjem i uploadom programa na dambu.
Radim sa basic2 i sve mi radi OK (kompile i upload), ali kada probam program prebacit na dambu ne mogu:
Ne radi kompajliranje
Kada izbacim dio koda i kompajliranje mi prođe ne radi mi upload
Molim neke smjernice.
U prilogu detaljniji info.
Unaprijed hvala,
Voditelj automat kluba
Wettpunkt d.o.o.
Branimirova 29, 10 000 Zagreb
A.K. “Wettpunkt Picasso Rijeka”
J.P. Kamova 81/A, 51 000 Rijeka
Croatia
M:
F:
T:
[email removed]
www.wettpunkt.hr (http://www.wettpunkt.hr/)
Virus-free. www.avast.com (Turvallinen sähköposti | Avast)
Attachment omitted in migration: Damba Problem.pdf
Originally submitted via email support on 11 May 2016. Migrated to the forum for community visibility.
First, are you following our tutorial: https://e-radionica.com/hr/blog/2016/03/07/kako-programirati-croduino-damba/
It would also help to see the code you’re compiling, as not all libraries work with this package. Here’s a list from an older version’s references; the newer version doesn’t have a similar list, but these commands should be supported:
- pinMode()
- digitalWrite()
- digitalRead()
- analogRead()
- analogWrite()
- shiftOut()
- pulseIn()
- millis()
- micros()
- delay()
- delayMicroseconds()
- SoftwareSerial (has been updated in Arduino 1.0)
moram prvo upitati radite li prema našem tutorialu: https://e-radionica.com/hr/blog/2016/03/07/kako-programirati-croduino-damba/
Pomoglo bi i da vidim kod koji kompajlate, jer ne rade svi library-i s ovim packageom. Ovo je popis iz referenci starije verzije, novija nema sličan popis, vjerovatno su podržani još neki:
The following Arduino commands should be supported:
pinMode()
digitalWrite()
digitalRead()
analogRead()
analogWrite()
shiftOut()
pulseIn()
millis()
micros()
delay()
delayMicroseconds()
I am following that tutorial. In the meantime I installed the IDE on another computer (MAC) with the same version and compilation works there. However, I also couldn’t get the upload to work (I’ll try with another Damba - it might be a hardware issue). The code I’m testing with is blinking LEDs on D0. I’m not sure about power supply during code upload. Do I need to connect power or does the controller get power through one of the programming pins?
Hvala na brzom odgovoru.
Da radim prema tom tutorialu.
U međuvremenu sam instalirao IDE na drugo računalo (MAC) istu verziju i tamo kompajliranje radi. Ali također nisam uspio napravit upload (probat ću sa drugom dambom- možda je hardverski problem).
Kod s kojim testiram je “blink ledice na D0”.
Nisam siguran za napajanje prilikom uploada koda.
Treba li spojiti napajanje ili ga kontroler dobiva putem nekog od pinova za provramiranje?
You don’t need to connect a battery; power is supplied by the programmer board. Compilation is IDE-related - if it doesn’t work, the IDE is not properly installed or configured, likely something related to attiny85 wasn’t properly set up.
ne trebate spajati bateriju, napajanje se dobiva od pločice koja služi kao programator.
Kompaliranje je vezano uz IDE, ako ne radi, nije dobro instaliran/posešen IDE, vjerojatno nešto vezano uz attiny85 nije dobro ubačeno.
