Croduino ethernet shield compatibility and cable options
I’m interested in an ethernet shield for Croduino. Is any custom adapter element required between the ethernet module and Croduino?
Also: do you have suitable cables for connecting Croduino with a 7-segment display and LCD display?
Zanima me ethernet shield za croduino,
da li se zahtijeva neki prilagodni element izmedju ethernet modula i croduina?
Drugo: da li imate neke prikladne kabele za povezivanje croduina s 7 segm displejem i LCD displejem.?
Hvala unaprijed
MarjanAnic
Sent from Yahoo Mail on Android
Date:sri, lip 24, 2015 at 18:55
Modul ima integrirane pull-u otpornike te regulator, tako da je dovoljno povezati kablice s kontrolerom.
Mozete spojiti +5V na Vcc pin.
Originally submitted via email support on 25 January 2016. Migrated to the forum for community visibility.
The module has integrated pull-up resistors and a regulator, so it’s sufficient to connect the cables to the controller. You can connect +5V to the Vcc pin.
We have a compatible shield for this: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Alternatively, you can connect using male-female cables. You can see the cable selection at this link: Kompleti i paketi | STEM elektronički kompleti – Soldered Electronics
imamo prilagođen shield za isto: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Alternativno, možete spojiti preko muško-ženskih kablića.
