Croduino NOVA Cannot upload sketch: esptool.exe not found error
I cannot upload a sketch to my Croduino NOVA. The upload fails with an error that suggests the libraries may not be installed correctly.
Originally submitted via Facebook on 11 March 2018. Migrated to the forum for community visibility.
The error message is: java.io.IOException: Cannot run program “REMOVE/esptool.exe”: CreateProcess error=2, Impossibile trovare il file specificato
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:130)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:209)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.Sketch.upload(Sketch.java:1187)
at processing.app.Sketch.exportApplet(Sketch.java:1160)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, Impossibile trovare il file specificato
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl. (ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 9 more
Errore durante il caricamento dello sketch
Original message (Italian)
… 9 more
This is a compile error, not an upload error. Try updating your Arduino IDE. Your version may be outdated for the new esptool (needed to compile and upload). The latest version is available at https://www.arduino.cc/en/Main/Software
I have already updated to the latest version 1.8.5 but the error persists.
Check what version of esptool you have by going to Tools > Board > Board Manager, search for “esp”, and update if needed.
I updated esp8266 to the latest version and now it works with the Hello Server sketch.
