Croduino NOVA DHT11 sensor returning 0% humidity and 0°C temperature
I want to connect a Croduino NOVA board, an experimental board, and a DHT11 temperature and humidity sensor. What cables do I need to connect all the components together?
Želio bih naručiti Croduino NOVA pločicu, eksperimentalnu pločicu te senzor temperature i vlage DHT11. Zanima me kakvi kablići su mi potrebni kako bi spojio sve komponente u cjelinu? Unaprijed hvala na odgovoru.
LP, [name removed].
Originally submitted via email support on 1 June 2017. Migrated to the forum for community visibility.
You can use a cable set for the experimental board: Set kablića za eksperimentalnu pločicu, 65 komada – Soldered Electronics
On the Croduino NOVA, install male headers and you can plug it into the experimental board, along with the DHT11.
If you don’t have headers: https://e-radionica.com/hr/muski-header-40-pinski.html
možete koristiti set kablića za eksperimentalnu pločicu: Set kablića za eksperimentalnu pločicu, 65 komada – Soldered Electronics
Na Croduino NOVA stavite muške headere te ju možete ubosti u eksperimentalnu pločicu, kao i DHT11.
Ako nemate headere: https://e-radionica.com/hr/muski-header-40-pinski.html
I bought a Croduino NOVA and a DHT11 temperature and humidity sensor. I connected everything according to the instructions and installed Arduino 1.8.2. I added the DHT library and added a 10 kOhm resistor as shown in the schematic. However, when I copy the code you posted on the website and upload it to the board, the serial monitor constantly shows humidity at 0% and temperature at 0°C. I’ve even checked the voltage on the sensor and everything seems fine. I don’t know what to do next. Do you have any ideas? I’m sending you a picture of how I connected everything.
Kupio sam Croduino NOVA te senzor za temperaturu i vlagu DHT11. Sve sam spojio prema uputama te instalirao Arduino 1.8.2. Dodao sam library za dht i dodao sam otpornik od 10 kOhm kao na skici. Međutim, kada prekopiram kod koji ste postavili na stranicu i ubacim ga u pločicu, serial monitor mi cijelo vrijeme pokazuje da je vlažnost 0% te temperatura 0 stupnjeva. Čak sam provjerio i napon na senzoru i sve se čini u redu. Ne znam što da dalje radim. Imate kakvu ideju? U prilogu Vam šaljem sliku kako sam sve spojio.
LP, [name removed].
I solved the problem from my previous message, but now when I upload any code to the board, it doesn’t work and the white and blue TX LEDs stay on constantly. I tried with the simplest LED blink code, but it doesn’t work either. Do you know what the problem might be? I’m sending you a picture of the board so you can see which LEDs I’m referring to.
Rješio sam problem koji sam imao u prošlom mailu, ali sada kada postavim bilo koji kod u pločicu, on ne radi i cijelo vrijeme su upaljene bijela i plava tx LED-ica. Probao sam sa najjednostavnijim kodom za blinkanje LED-ice, ali ni on ne radi. Znate li u čemu je problem? Unaprijed zahvaljujem, šaljem Vam i sliku pločice da vidite o kojim je lampicama riječ.
Please make sure the attachments you send are smaller than 1MB; unfortunately we cannot see the ones that have arrived so far.
How did you solve the DHT sensor problem? What code did you use and how did you connect the sensor?
molim te da priloge koje šalješ budu manji od 1MB, nažalost ne možemo vidjeti ove koji su do sada došli.
Kako ste rješili problem s DHT senzorom? Koji kod ste koristili i kako ste povezali senzor?
