Croduino NOVA hosting web server and static IP configuration
I purchased a Croduino WIFI and tested the code from your website. I’m not clear on how to open the web page that the Croduino hosts.
This is my output on Com5:
m ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮…We are connected to WiFi! IP address is:
192.168.0.17
Now connecting to e-radionica.com
We are connected to the page. Now we will open URL: /hr/
Done. Closing connection.
Pozdrav, kupio sam croduino wifi kod vas, te sam isprobao kod koji je na vašoj web stranici. Nije mi jasno kako otvoriti web stranicu koju croduino hosta?
ovo je moj output na Com5:
m ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮…Povezani smo na WiFi! IP adresa je:
192.168.0.17
Sada se povezujem na e-radionica.com
Povezani smo na stranicu. Sada cemo otvoriti URL: /hr/
Gotovo. Prekidamo konekciju.
Originally submitted via email support on 21 May 2018. Migrated to the forum for community visibility.
The code you’re testing is using Croduino as a client, not a server. It’s connecting to an external website on the internet, not hosting a page.
To host a web page, you need to configure Croduino NOVA as a server. Start with this tutorial: https://e-radionica.com/hr/blog/2017/12/10/croduino-nova-kao-server-a-k-a-kako-spojiti-uredaje-s-croduino-nova/
hvala na kupovini! Ovo što pokušavate je koristiti Croduino kao client, dakle on ne hosta stranicu, nego otvara treću stranicu na internetu.
Vi trebate iskonfigurirati NOVU kao server, da bi hostala stranicu. Pronađite ovdje tutorijal za to: https://e-radionica.com/hr/blog/2017/12/10/croduino-nova-kao-server-a-k-a-kako-spojiti-uredaje-s-croduino-nova/
The PC and Croduino are connected to the same WiFi network.
PC i croduino su spojeni na istu wifi mrežu
Use the tutorial link I sent you to set up the Croduino NOVA as a server so you can read data from your PC.
You then need to read data from Croduino NOVA and display it on the web page. This part isn’t covered in the tutorial, but we have other tutorials for reading from sensors. For displaying the data, you’ll need HTML - there are many tutorials available online for that.
za to trebate koristiti link kojega sam Vam poslao - za početak. On će uspostaviti server na NOVOj tako da s računala možete čitati podatke.
Sve što još trebate je očitati te podatke s NOVE i prikazati ih na web stranici.. taj dio nije pokriven u tutorijalu, ali imamo druge tutorijale za čitanje sa senzora, a što se tiče prikazivanja tih podataka - to je html.. ima dosta tutorijala na netu.
Isprike što mi nemamo nekakav takav tutorijal za to, dodao sam na popis pa budemo složili u izvjesnom vremenu.
Is the IP address that Croduino has static or dynamic? How can I set it to static so the Croduino keeps the same address if the router resets?
PS: da li je ip adresa koji croduino ima je statična ili dinamična, i kako ju stavit da je statična, ako se routher resetira da croduino ima istu adresu?
According to the tutorial, the LED is on pin 2 by default. If you want to use it on pin 13, change the ledPin variable from 2 to 13 on the sixth line of the code.
For a static local IP address, configure your router’s DHCP settings to bind the MAC address of your Croduino NOVA to a fixed IP address. You can find instructions for this in your router’s manual or online.
po ovom tutorijalu, LEDica je po defaultu na pinu broj 2. Ako je želite koristiti na pinu broj 13, promijenite varijablu ledPin s 2 na 13 u šestoj liniji koda.
Ako trebate statičnu lokalnu IP adresu, trebate u postavkama svog rutera, na DHCP postavkama, povezati MAC adresu Vašeg Croduino NOVA s fixnom IP adresom. Upute za to možete pronaći u uputama rutera / internetu.
